Help with boosted Alpha-N
My engine runs great using Speed Density except at idle. I have switched to Alpha-N to test tunning idle and it works very well. How can I set it up to use Alpha-N up to 1500 RPM and Speed-Denisty after. I can't seem to get my head around ITB mode. Would that work? I have searched on the subject but like I said I just can't seem to get it.
1982 porsche 930
Re: Help with boosted Alpha-N
To do this, use a set of tables in multiplicative mode. Set the SD table to 100% below 1500, and set the alpha-N table to 100% above 1500 RPM.
Could you explain this a little further. I feel about as smart as a brick but I don't realy get how to set that up.
1982 porsche 930
That link did help. Thank you Matt. I think it would take tuning everything over again or am I wrong? I tried using idle ve also and it helped a little. Is it possible to make the idle ve table alpha-n and still keep ve table 1 speed density? The thing runs great soon I touch the the pedal.
1982 porsche 930
You would only need to tune the idle portion again if you go that route; the part above 1500 RPM would stay untouched.
IF it was tuned with "Multiply MAP" off, yes.
