Low spikes in TPS & MAP at wide open throttle MS3X
Viewing a few a logs from different days, both logs using Shadow Logger, noticed short, low spikes in TPS & MAP. Not sure if any misfire, can anyone see a cause viewing logs? Thanks.
Re: Low spikes in TPS & MAP at wide open throttle MS3X
The only "spike" I saw looks like partially lifting while shifting into a higher gear.
Thanks for reply, not lifting, have an automatic. Other log 1.5mb, too big to upload, here an image of a wide open throttle run never lifting. Sensor 01 is heat exchanger water temp. Sensor 02 is turbo compressor out temp. Thanks.
You could put the log in a ZIP file or trim it with MegaLogViewer's trimming function.
Couldn't find Megalog Viewer trimmer, edited with MS Word.Matt Cramer wrote:You could put the log in a ZIP file or trim it with MegaLogViewer's trimming function.
After uploading trimmed log, I studied log, those glitches were from rev limiter, have it set at 6,000 with 100 hysterious. Never thought it would affect TPS value.
Went for a ride after to confirm, all good! Thanks
