Just wanted to confirm with you guys about the wiring for the check engine light. Seems really simple, but I don't want to fry anything. Since I am running MS3/MS3X all I have to do is choose an unused PWM output on the MS3X connector correct?. So in my case I will use the VVT output as a switching ground for my CEL with a 12v bulb. The manual states "Small indicator bulbs may also be directly connected." So pretty much any sort of automotive dash bulb like a 194 correct?
Sorry for the remedial question, but I have so much swirling around in my head I just want to be sure
Check Engine Light
Check Engine Light
http://www.buildpics.org/
Re: Check Engine Light
All sounds fine to me.
