Start up Tune Check
Can one of you fine experienced megasquirt users check over my msq for mistakes before I try my first start I just want to make sure Im in the ball park and wont blow anything up.
My specs are as follows
ECU is a ms3x from Diyauto tune (prebuilt) wired thru a relay board
Small Block 351w ford stroked to 393cid.
Running custom cross ram ITB's with air boxes merged together and thru a 90mm Lmaf
3,8l v6 ford cam sync adapted to the 351w block
diyautotune 36-1 crank wheel and hall sensor
42lb hr Delphi injectors full sequential
ls2 coils full sequential (car coils not truck)
Gm style IAT CLT sensors also from DIY autotune
84 corvette stepper iac valve
89 mustang tps
The Cam shaft is a hydraulic roller so the engine wont see over 5800rpm.
The firm ware 0n the MS3 is 1.3.2
The MAF curve was loaded from the LMAF file that came with 1.3.2 hope its close to what is needed
Im hoping someone can look at the MSQ and point out glaring dumb mistakes and maybe some advise on features to have turned off/on on first start.
If you need more specs pic's or whatever just ask hopfully there is enough info here
Check over Startup MSQ
Re: Check over Startup MSQ
do you have the jumper installed at jp7 on the x card? im using the same cam synchronize you are using. 5.2.14.2 Cam sensor input - open-collector hall sensor / optical sensor or 5.2.14.3 Cam sensor input - hall or logic sensor. i put a jumper on mine and the computer is saying no cam input.
Wow, how did we let this thread slip by with no reply until now? Let's hope the OP is long-past "first start" and isn't discouraged about MS or the help available here!
yes i know. im having the same problem. i have tried everything.
Okay what is your problem? The (neglected) OP that started this thread was just looking for somebody to check for errors before first start, no specific problem was mentioned.
Edit: you are getting no response to this thread, is that the immediate problem?
http://www.msextra.com/forums/viewtopic ... 31&t=57730
you were on my other post about cam sync problem.
No worries guys I re checked every thing and just went for it and it fired up so fast it actually scared me half to death. It runs great I guess the year of
reading payed off.
reading payed off.
