Hello to all,
Long time ago i've put MS3 + MS3X into nissan laurel with RB25DET engine. There have been some diy inside MS case: knock module soldered over ms3 daughter.
Everithing works fine except knock module. it always shows 101.2%
But this is not the main problem. Main problem, that sometimes car die unexpectedly. When it die, car will not start until ignition will turned off and on. Also, fuel pump operates infinitly.
FIrmware version 1.3.0.
Attached datalog is the last log that was on SD card, just after car dies.
Thank you
MS3X random die on RB25DET
MS3PNP (diy) powered mazda RX-7 FD 13B-REW. bw S366. 410hp pump gas
Re: MS3X random die on RB25DET
Have you seen this. http://www.msextra.com/forums/viewtopic ... 57#p408457
have not. Thank for the reply. i'll try to upload fixed code.
