I can't start my jeep V8
On the gauge cluster I can see that the fuel load says INVALID (???).
Where might be the problem?
I have attached a data log. Also a shot screen with the engine running with its own fuel and ignition system.
Re: I can't start my jeep V8
Looks like you need to:
1. Confirm the timing is correct.
2. Adjust the cranking pulse width.
The invalid fuel load is purely a TunerStudio gauge setting issue. Right click on the dash, select Load / Save, and reload the default dash - it should come up with the fuel load displayed correctly.
I'm very happy . I have already started my engine, no very well, but it runs...
I'm going to install a wideband o2 sensor and then I'll try autotune with TunerStudio.
Thanks.
Thanks.
