Knock module wiring for V 3.0 board
The installation instructions for the knock module show "proposed wiring for DB15 connector" - but this connector is only on the V3.57 board; are there wiring instructions for the V3.0 board? Thanks!
Re: Knock module wiring for V 3.0 board
You can either add an extra connector or use any unused pins on the DB37.
I used two of the "SPR" wires for the two knock sensors
http://web.aanet.com.au/arran
