12v on v3 inj2. (error 40)
Made a stupid mistake today. Using the 2 injector output as highpower output. Doing a test, i wanted to activate the outputs without using the ecu. I forgot to disconnect the ecu and therefore I supplied 12v to the v3 inj2 output. Car starts and runs, am i okay? Have I just burned the BIP?
Re: 12v on v3 inj2. (error 40)
You may have burned the INJ2 drive transistor, but probably not much else.
Okay. Thank you. I noticed a little burned area on the board around the transistor. I made a puf sound followed by smoke.
