I need to move from my 4 bar GM map sensor to a 5 bar AEM sensor. After changing the sensor in the drop down, what is the best way to re-scale my ve and ignition tables ? Also am I forgetting anything else to upgrade ?
Thanks, Jeff
Upping to a higher map sensor
Fastest MS powered vehicle on the planet ! 6.60@208mph
Re: Upping to a higher map sensor
Click on the arrow near the bottom left of the ve and timing tables, it points up and across. Here you can rescale the tables and the software will interpolate th correct numbers and then you can add the desired bins
