Hey guys
I am currently working on a RB25DET S2 engine. I wired everything up and all is working except the trigger system.
I have done the modifications to the ms3 and the trigger wiring like it is shown on diyautotune website. (http://www.diyautotune.com/tech_article ... b25det.htm)
I already played with different resistors and with a rotated pinout of the nissan cas. I only get the 1° trigger signal working.
I attached a log and the msq, perhaps one of you have an idea, cause the only way i would go now is a custom 36-1 trigger.
Yours sincerely
Heiko
RB25DET S2 on MS3X - bad cas trigger
Re: RB25DET S2 on MS3X - bad cas trigger
I've tested a VG30DETT CAS on the bench following the instructions in the manual here and it works.
Can you get the low resolution signal working on a Stim? (You may need to use a different wheel mode or even Basic Trigger to test it.)
