JoseMiguel wrote:After practically re-wiring the whole car, I think we found the problem, and is as stupid as ever...
to make things neater, we used connectors in all the cables, including the quad-spark grounding. Unfortunately, we found that the quad-spark connector was not crimped correctly and it made false contact with the ground!
the light of hope shines ahead! im crossing my fingers here
that totally doesn't sound like the fix or the issue, if you can get it to revlimit just fine offboost, on-boost death must be boost-related, and fuel related. your dwell is static, so boost 6000 rpm or no boost 6000 rpm should be same.
unless it's misfires if the coils can't deliver a proper spark.
what are the plugs gapped at ?
