just seems odd that it would work at all if you had the coils wired wrong.JoseMiguel wrote:Yes, I tried many sets of injectors, these are the smallest we had for testinggurov wrote:what injectors are these ? any way you can throw much larger injectors into this thing ? duty cycle goes pretty high up.
i once had a crazy issue like this in the supra, turned out to be a dirty fuel filter, and the injectors were large enough to cause a pressure drop at the rail.
But I think we found the problem as documented in the last few threads. Tomorrow morning im re wiring the coils and see what happens!
can you pull the coils out, rig up some extra spark plugs to them, disconnect the injectors and use the ms's ignition test mode to drive coils past the speed/dwell they are as is ?
