As most will be aware, the SDcard for datalogging is internal in the MS3-Pro and datalogs are retrieved over the serial line. (On MS3 the card can be ejected and plugged directly into a computer.)
There is a feature that you may not be aware of in the 1.3.x and upwards firmwares. It is a setting on the Communications->Megasquirt Baud Rate screen called
"SDcard Readback Baud Rate" - this bumps up the communications speed when pulling back logs from the card.
The standard baud rate is 115200, this setting also allows higher speeds.
230400 - works on the bench and in my car. 50-100% quicker.
300000 - does not seem to work.
460800 - works over direct USB on the bench - datalogs fly back. Does not work with my USB-serial adapter.
Please try this out and report your successes or otherwise here.
Attn: MS3-Pro users - SDcard readback baud
Re: Attn: MS3-Pro users - SDcard readback baud
Will this be available for MS3 as well as Pro?
My ECU is stored in the OEM location, in the drivers footwell. Removing the SDCard is a ballache. Retieving short logs though the on board USB port is bearable, but longer logs are horrific.
2003 MX5. Coldside MP62
This is already available on MS3, I aimed the post at MS3-Pro users as the SDcard is internal, so readback speed really matters.richyvrlimited wrote:Will this be available for MS3 as well as Pro?
Well I will try this out this weekend. I will be providing trackside support for a pair of MS3 equipped road race cars at Sebring.
Support the developers!
Ok, so I really like the high speed read from SD We run 20-30 minute sessions and cutting the download time in half is awesome! never had any troubles with it or any garbled data either.
