Egt question
thecrew2999
Egt question
Post by thecrew2999 »
I have Ms3 with the msx card with several other mods. I would like to be able to use 6 egt inputs to tune my car. My Ms3 does not have canbus on it what options do I have? Can I upgrade to canbus like trade my old in or is there another way to wire up 6 egts?
racingmini_mtl
Re: Egt question
Post by racingmini_mtl »
All MS3s have a CAN bus. It may not be wired to your connector but check to make sure. If that's really the case, it's simply a question of running some wires to spare connector pins or to a new connector.
And that's the only way to get 6 EGTs; there aren't enough analog inputs on the MS3 to do it directly. You can use the DIYAutotune unit or you can use one of my units (check my forum (link in signature) or contact me).
thecrew2999
Re: Egt question
I would like to run a spare connector for canbus. Is there some documentation on where I would wire these from?
Re: Egt question
The jumpers for the CAN wires are covered in the MS3 Hardware manual PDFs. See the manuals link above.
thecrew2999
Re: Egt question
Thanks having a heck of a time finding it but I'm sure I will... thanks again
Re: Egt question
Does this help?
From the "Manuals" link above.
i.e. http://www.msextra.com/doc/index.html#ms3
thecrew2999
Re: Egt question
Ok correction I can not find any documents about wiring up can bus on my none pre installed can bus board.
Re: Egt question
(Easy for me to find because I wrote it)
Try here:
MS3base/V3.0 Hardware Guide
3.4.12
CAN comms
The CANH/L wires are used to connect to add-on units such as transmission control, CANEGT interfaces, data
capture or compatible dashboards.
The Megasquirt includes a terminating resistor.
To use the CAN connections, you need to run internal jumper wires:
JS6 -> SPR1 = CANH
JS8 -> SPR2 = CANL
This is also mentioned in the assembly section.
thecrew2999
Re: Egt question
Racing mini I sent you a pm..
Also I got this figured out now thanks for the replies. I'm still a little lost why the newer ones have the plugs built on them with all the pins. What are they for if can bus only needs 2 wires
Re: Egt question
Which "newer ones" and pins?
thecrew2999
Re: Egt question
My megasquirt has 3 main plugs not counting the USB. Has the db db 9 and the one for the msx card. The new megasquirt have a 4th plug for can bus it's labeled
Re: Egt question
I've not seen that, can you post a link?
thecrew2999
Re: Egt question
racingmini_mtl
Re: Egt question
The DB9 connector on the left is for the RS232 serial connection and the DB15 connector on the right is for optional inputs/outputs. It is not a CAN connector. If the instructions are followed (as per James post and the manual), the CAN connections are 2 pins on the main DB37.
Re: Egt question
For the next release, I've updated the new hardware manuals to clarify what the connectors do to hopefully save this confusion in the future.
radial
Re: Egt question
Post by radial »
Just an suggestion:
Can't the DB15 plug be used for CAN-purposes?
IAW this, Pin 3, 10 and 11 is not used.
As this plug is for external inputs/outputs anyway.
Toyota JZX90 Mark II drifter
1JZ-GTE, 12+1 on MS3x, 6x LS7 D514's, 510cc, all stock sensors
racingmini_mtl
Re: Egt question
Yes you could do that. However, all the wiring diagrams show the CAN pins on the main DB37 so that may be confusing. If not for you, it may be for some else looking at your setup or a new owner if you sell the unit.
And the standard won't be changed because there is no DB15 on the V3.0 board so the CAN pins have to be connected to the DB37. And having 2 different standards for the 2 boards would be confusing for everyone.
