Is there a way to disable this? Or select something in this field so it is always on? I'm using it to control my electric VAC pump. But I don't need to wire the input side. I've already tested the wiring in the I/O test. Pump comes on great with the N201 output. I'd like to set it up as always on above 80% on the TPS.
Its the "Enable Input ON"
Nitrous input necessary?
Re: Nitrous input necessary?
Don't you want to use programmable outputs instead?
MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next.
2333(103*70) Type 4 with DTM also sitting in living room just need exhaust.
Still pretty new to this thats a much better way to do it.
Look in the section on wiring input/outputs, there are several outputs that can be configured to do what you want, and they are capable of directly running a relay or some of the small vac pumps .
go the the manuals and check or search for wiring outputs.... you should be able to use several different positions.
I set the VAC pump to come at anything above 100kpa in the custom I/O section. (used a relay) Works great.
