Hi all,
I've been looking at the "Boost vs Speed/Gear" settings as I want to reduce the amount of boost in first gear.
My question is about the units of the "per gear targets".
Is the unit kPa as shown?
My head is telling me I'm looking for a percentage (of the target table).
I've checked out the new manuals and I'm looking for more info on how the per gear target kPa interacts with the values in the "Boost targets" table (rpm versus throttle)?
If the per gear target was a percentage it would be based from the table, but if it is a kPa does it override the table with just a flat setting for all throttle and rpms in that gear?
Am I making sense!?
Thanks in advance,
Arran
"Boost vs Speed/Gear" usage question
http://web.aanet.com.au/arran
Re: "Boost vs Speed/Gear" usage question
If using boost by gear the actual target table is ignored and the per gear units are used. Depending on the firmware the initial value or bias table needs tuned still
As a test so you can see the relation input some values that your tuned closely too. Let's say it's 200kpa. Make first gear 190, second gear 195, third 200 and fourth 205. To make a pull (doesn't need to be to redline either just plenty high in the revs to get boost goin) and datalog this. Check out the lot under boost1 targets and you should see the desired effect
Thanks.
