5cyl 60-2+distributor cam sensor configuration questions
so I finally got everything installed and wired in yesterday for my crank trigger hall sensor and a one window distributor being used as a cam sensor. I removed/changed the components and added jumpers as described here http://msextra.com/doc/general/tachin-v ... #spareopto and I configured MS as best as I could from what little 5cyl info I could find in the manual/here/and MSextra stuff.
Now I am not seeing an RPM signal in megasquirt and I am relatively certain it has something to do with my configuration. I thought maybe if I posted a couple pics here someone might see a red flag in my setup. my crank signal seems to be getting thru according to the tooth logger but I still don't see any tach signal.
when I found this write up: http://forums.turbobricks.com/showthread.php?t=126892
I noticed he said to describe it as a 120 tooth wheel but never touched on why or if I needed to then tell ms it is a cam wheel or if it was now 4 missing teeth. . . but once again its all old ms1 extra stuff and not easy to tell if it translates well into ms3
here is my ignition configuration, I have tried describing it as both a single wheel with missing teeth and a dual wheel missing teeth but I haven't tried the 120 tooth thing yet.
just not sure what to try next and im not really sure how to tell if the cam signal is getting in at all. I sent the signal for it to IAC 2A since it wasn't being used. jumpered that to XG1 like the schematic says for the secondary cam sensor input. the only other thing I can think of, since mine is a 3.57 some of the 3.0 mod instructions are a little unclear. I jumpered JS2 which I believe to be optoout to JS10. . . could that be my mistake? wrong opto out maybe??
Re: 5cyl 60-2+distributor cam sensor configuration questions
See section 5.2.14 in the MS3base/V357 Hardware Manual.
Describe your current cam trigger setup. You still on dizzy or cop? If the former use single wheel with missing and you should see rpm with no cam input.
You can't have a crank-only signal with a 5-cylinder engine (or any odd-numbered engine).Paul_VR6 wrote:Describe your current cam trigger setup. You still on dizzy or cop? If the former use single wheel with missing and you should see rpm with no cam input.
You should take a composite log to see if the cam signal is actually registering.
jsmcortina: thanks for that link. missed that one somehow. changed the ecu setup exactly as section describes but im still wondering a few things about my tuner studio configuration. gonna try logging it after dinner tonight.
Paul_vr6: description is in the first post. single coil distributor based. it needs the "cam sensor" because you cant run wasted spark on a 5 cylinder. the cam sensor is there for crank/cam phasing to tell the computer where TDC compression stroke is. I have already run into many "because 5 cylinder" scenarios and im sure im not out of the woods yet
I made the changes needed in 5.2.14.3, im running my signal into IAC2A in the harness and IAC2A on the main board jumpered to JP1 pin 3. any chance that's a bad in/output to use for this? Im not using the IAC circuit for anything else and the only other jumpers I did were for the hall effect trigger, both my sensors being hall I left all that alone
did a composite log and its still not seeing any cam signal
I checked a few things today, good power and ground at the sensor, good continuity on the signal wire from the sensor to the db37. I even switched from using IAC2A to SPR4 just incase that was a bad input to use. double checked all the steps called for in the manual 5.2.14.3 still no signal. the only other thought I had was do I need to jumper from the spr4 pad on the board to the pin itself?
what am I missing here?? do I need to remove jumpers previously installed for the hall opto input? I just don't know what else to try at this point without an oscilloscope
You need to be using the vr circuit for crank and the opto or direct wiring for the hall.
What wire/pin is the cam coming in on and exactly where does it go on the board after?
Ps: sorry about the bad advice, read the title as 6cyl
no problem. the input is going from the sensor to spr4 in the DIY harness (pin 6) and from there its jumpered to JP3 as it says to do in the ms3base/3.57 manual.
