Hi all,
MSQ is attached. No problems with signals or sensors. I just can't seem to figure out how to tune prime/crank/ASE/WUE...
MS3, 3X (3.54)
Project is a 1995 Chevy Cavalier. 2.2 liter OHV 4 cylinder. All stock except for a real cold air box with K&N cone filter, OBX 4/2/1 header with Flowmaster 40/generic Catcon.
I'm using LS2 truck coils. Manual trans. Sequential fueling of stock injectors. 36-1 wheel
In case you're wondering why someone would put all this MS stuff on a car that's not worth as much as the MS... a LS4 will bolt right up to the stock trans. 300 hp; 325 #ft !!
When it's cold it cranks 5 times longer than it should and I have to pump the throttle 3-4 times, then go full throttle for a second and then slowly return toward idle. It usually starts but then I have to pump the throttle to get it to run cleanly. After 30 seconds I can let it to idle and all is well.
Warm restarts are better but not good compared to the factory ECU. It starts, runs for a few seconds and dies, with the second crank attempt doing nothing. On the third try it starts and runs normally.
Thanks to all for the help. I'd like to make it to the meet on Sat but have to work.
Dennis
Need help with starting issues
Re: Need help with starting issues
A log fie to go along with your msq would be very helpful...........,
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
a couple of things I noticed, your injector dead time is 1.3ms, that seems like a long time.. my injectors dead time are .6ms, and some of my injector sets have dead times of .35ms... but I have never tested a set that was more than 1.0ms.
in your ego/o2 set up you have the corrections above 17 and below 13.5, your sensor isn't being allowed to correct for any of the values in your afr table. it can only correct values from 17 to 22 and 13.5 to 8. and these values are not in your afr target table. if you want it to make corrections in the tables ranges, then the above limit needs to be 9 or 10 and the below limit needs to be 17 or 18..
this will allow your ego corrections to happen when you want them.
also your cranking pulsewidths seem kinda high, if your port injected and not throttle body injected you are not loosing a lot of fuel in the way to the cylinder, so you don't need the large fuel pulsewidth during cranking. you're likely flooding the engine and that is why pumping the throttle helps it fire up.
I would cut the cranking pulsewidth values in half, and any values above 140 degrees coolant should be set to 100% and try that... see if that helps. remember those values are a % of the required fuel so 150 is i.5 times the required fuel... and 100 is the actual required fuel.
good luck.
good luck.
Please forgive my extremely tardy reply. I missed it...must need new glasses.
Thanks for your input. I will adjust and report back.
Dennis
Dennis
kaeman wrote:a couple of things I noticed, your injector dead time is 1.3ms, that seems like a long time.. my injectors dead time are .6ms, and some of my injector sets have dead times of .35ms... but I have never tested a set that was more than 1.0ms.
good luck.
