help with timing
help with timing
Pretty new to this tuning and my car is showing the advance idle at 32*. I think it is to high. dont no how to adjust.
motor is 6.0 ls with turbo running ms3/ms3x semi sequential and wasted cop.
any help would be greatly appreciated.
Re: help with timing
Also post your tune (.msq) file.
my latest tune.
See the spark table section of the manual, starting here:
http://www.msextra.com/doc/pdf/html/Meg ... e-1.3.html
would it be to my benefit to use toothed wheel instead of ls1 option in the ignition options/wheel decoder. the reason is i have seen other tunes, on other cars with the same 6.0 ls and turbo. My 6.0 is an ls but not an ls1.
The "LS1" option applies to all engines which use the 24X pattern. Leave that set.
ok thanks for the quick reply, i am just getting frustrated with the idleing at 1200rpm and 32* timing.
matt, could you narrow down to what page that could be on in the manual? thanks
i got the engine to TDC and put a dial back timing light on it. I went into the ignition options/wheel decoder and changed from use table to fixed advance 10. started the engine, kept it at 1k rpm and the timing light read 5 degrees. Not sure if this was the right, but i change the trigger angle/offset degree to 5? Is this right? The motor is a 6.0 ls running wasted cop and semi sequential.
Sorry, meant to link to the ignition tables, starting on page 143. http://www.msextra.com/doc/pdf/html/Meg ... 3-143.html
thanks going to set the cranking advance to 0 and start from there.
