jsmcortina wrote:ragepower wrote:EDIT: The dyno owner suggests me that maybe the Ms doesn't had good ground connections. I need to make more. I have two 2 mm wire (one for mainboard, other for ms3x), one 2 mm wire for bip373 ground and 2 more for iox board.
Certainly worth investigating.
I had re-wired the ground cables on the engine head, add 2 more, 1 for mainboard, another for MS3X card. Just in case.
ragepower wrote:
- If I had the usb cable connected to laptop, I will have lost sync at 5700 / 6000 rpm. If I disconnect it, I do dyno run to rev limiter without lost sync. Due to this, I can't tune vvt to 6000 and 7000 rpm column and I can't do datalogs on dyno runs.
I think was because I have 1 usb cable inside the main box, that was rolled to be organised, maybe this had reduced the noise resistance.
ragepower wrote:- I have something happening at 5300rpm. Until then, I have a bit smoke (maybe 12.5 is too much this engine) then no smoke and the engine seams to knock. Maybe need more fuel but the afr isn't lower than 13.
Can I trust on WB sensor on high load and high speed?
And there is always something wrong, because the gases from the exhaust don't has a fuel smell but them "burn" my eyes.
ragepower wrote:AbatelliCristian wrote:I have a feeling that the module does knock not dialogues with ecu... the setting is correct...
check wiring of the module.
Checked. It is OK.
Can I check if it is working by setting the bandpass frequency filter to the max or to the min, so the knock gauge reach the max?
Can I do this?
EDIT: I will try to find out to check if the knock sensor signal is reaching to the knock module, using a scope
