Unit of measurement closed-loop boost target map? Kpa? Psi?
I'm setting up some PID boost control action on the newest release firmware, I unlocked closed-loop for my control algorithm and noticed the graph came with values of 10.0 across the chart to start. Seems a bit low to be in kpa, so is it in psi? I saw one person who posted that their target map was so I just wanna be sure before I enter 10kpa that will do nothing or 220 psi which'll do all harm and no good!
Thanks,
D.V
Thanks,
D.V
Re: Unit of measurement closed-loop boost target map? Kpa? P
I haven't opened the new release yet but are you looking at the bias table or the target table? I could see 10 in the bias table for boost duty cycle
target table.nathaninwa wrote:I haven't opened the new release yet but are you looking at the bias table or the target table? I could see 10 in the bias table for boost duty cycle
I see. I'm on 1.4.1 which is the same boost setup. It's kpa and default is just funky. I target from 220 to 300
We will fix the defaults.
Does this mean it's in kpa?muythaibxr wrote:We will fix the defaults.
Edit:never mind guess it is!
Took a look at the defaults. They are already 100 across the board.
Basically yeah.
Please read the tool tip for the table. It tells you the units.
