Plug and play moronic 55 audi v8 twin turbo
I've been brewing this project for a while and I had to order a ms3 setup for a customer so I ordered the bob while I was at it. I got the kit from diyautotune but I didn't like the small box setup they sold with the kit so I went looking and this is what I found. It is a 6x8x2 project box that I can install a 3.0 board sideways by just leaving off the dB connectors or more likely I'll be getting the ms3 pro module for service in the box. I'll show more as I go but here are a few pics of my case
And here are a couple of the flywheel and turbo manifolds. The car is a 1990 audi 90 20v sedan and the motor is an audi 32valve dohc v8 3.6l PT all aluminum out of a 1990 audi v8 quattro.
Brent Savage
life behind the zion curtain
90 audi RS2 20VTQ 6sp MS3, MSX COP and Sequential and now MAF
87 Scirocco 2.0 ABA 16v EIP tubular cast MSII COP
86 Audi 4K20VTQ MSII
90 Audi 90 sedan 3.6l DOHC V8TT (project car)
89 VW cabbie (bitch basket) 2.0 ABA Turbo MSII
Re: Plug and play moronic 55 audi v8 twin turbo
This is going to be a sick project. Any shots of the car? What HP you shooting for?
There are a few pics of. The motor the red car is the one the motor Is going into. The green car is my other ms3 turbo s2 and is what the red one will look like when I am finished.
Brent Savage
Sweet!
I also wish to state for the record that I'm massively jealous of your flywheel with the "trigger wheel" machined into it.
Eric Law
Yeah that is a sweet thing... It looks like I can hog out the bellhousing by the stock crank sensors and weld/machine/fabricate a holder for a nice hall sensor off the stock crank sensor block. I have to look at the ABZ crank sensor set up and see how and where they go in. I might not have to do anything different. But I would prefer a hall sensor for ease of use and less noise connection problems than a VR setup. I am planning on using the stock passenger side distributor for cam signal, I should have enough clearance on that side of the engine compartment. I know the drivers distributor has to go, but it doesn't have a sensor in it anyways. I need to find some abz valve covers too I think.
Brent Savage
I just wanna know where you sourced the box!! It's perfect for a project I have in mind!
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I will find a link for you when. I get to work. The case part number was 6008 it was California and I didn't find an email about it in my inboxes. I was really pleased with the box. I was scared half to death when I opened the box and they had slid the two halfs together and the case only looked like it was an inch high.... but it is an exact match to the ms case but wider and deeper. Perfect for the bob boards plenty of room for additional modules and cards. The case was 35 plus shipping and tax brought it to about an even 50.
Brent Savage
http://www.scienceshopusa.com/product-p/ce-50423.htm
That should be the link for the box I got it was perfect. I had a harder time finding it the second time.....
Brent Savage
Thanks, Brent!
