Im getting to the point of having power hooked up to test everything.
I tested all coils and they are working fine, but I can't test the injectors.... The "start" button in TS is greyed out so I can't click on it.
1.3.0 FW w/ TS 2.6.04
I attached an .msq if it helps.
injector test start button greyed?
Here's a screen snip to show I'm not crazy...yet ..LOL
Re: injector test start button greyed?
in the screen shot the total number of injections is set to 0 does it make a diff if you change that number?
I did not see that setting... I will test and report back.
That did the trick....so I may not be "crazy" but unfortunatley the evidence points towards "stupid."
