Implementing air bypass style idle conrtol will be a PITA with 6 ITBs, is there any reason i cant simply pwm a solenoid to hold the throttle slightly open like used in the carby days?
My factory stepper motor ISCV is nicely packaged with a linear actuator, i could unbolt the bottom half which handles the airflow and simply mount the stepper/actuator to press on my throttle linkage which would be my preferred option
Will this work well enough?
PWM or stepper motor throttle stop idle control
Re: PWM or stepper motor throttle stop idle control
I've often thought of doing the same thing but haven't gotten around to it yet. I think you should go for it and let us know!
Graduate of EFI University.
