1 tooth crank and cam
Hello. I have 6 cylinder engine, MS3X, VR crank and cam sensors(1 tooth). Can I use sequential spark(COP) and injector. What setting I must set in TunerStudio in ignition options? I'm sorry if this question has already been discussed on the forum, or is in the instructions and for my bad english.
Re: 1 tooth crank and cam
Just to confirm, are you saying:
crank wheel has one tooth ?
cam wheel has one tooth ?
Crank wheel has one tooth and cam wheel has one tooth.
Unfortunanately, that will not work.
For a six cylinder engine, as a minimum you need three teeth on the crank. I would recommend installing an aftermarket 36-1 trigger wheel.
Thank you.
Is it possible there's a third sensor here that reads flywheel teeth? If so, how many teeth are on the flywheel?
