I have used almost every I/O on the MS3x, and I would like to put a VSS on this car-(seems like i have asked about this but could not find the post-sorry)
I have the nitrous1 input available-
if i use a hall effect sensor hooked up to 12V can I use this input as opposed to using a 5V ref?
If so will it be able to handle the high frequency input of a drive shaft reluctor with say 16 teeth?- I ask because it seems that some of the inputs were not capable and were dropping out at higher speeds-
Any feedback appreciated- thanks
will this work? VSS setup
Re: will this work? VSS setup
I don't see a problem with running a 12V Hall effect sensor to this input.
thanks Matt,Matt Cramer wrote:I don't see a problem with running a 12V Hall effect sensor to this input.
Any considerations to the amount of teeth i can run on drive line or ?
