ignorant question i have- when setting up the traction control, (example - perfect run, perfect run rpm - any that have a time based curve that must be started)
what starts the timer, and what stops/disables it? ( I assume it stops when it hits the last 'time' value on the curve)
"Traction Control Settings"/ "ENABLE INPUT" i assume this is the input that starts the timer? I was a bit confused because the note says optional switch input (if it is would it really be optional?) and there is no selection for which VSS to use, but maybe it defaults to VSS1?
What starts the timer?
Re: What starts the timer?
Exiting launch control. i.e. get on the limiter, then release the button.JAM wrote:ignorant question i have- when setting up the traction control, (example - perfect run, perfect run rpm - any that have a time based curve that must be started)
Yes.and what stops/disables it? ( I assume it stops when it hits the last 'time' value on the curve)
