Does anyone know if I will have to do anything special other than the typical Crank/Cam sensor circuit setup to Parallel a LS1 ECM with MS3x? I will just be installing secondary IAT/CLT sensors and tap into the TPS as well as wiring the IAC.
I have done two different LS1s already and now am looking do it on a non-engine swap vehicle that the owner would like to retain all the factory functions and gauges/displays as well as the factory transmission control. I feel pretty confident on everything but having a problem sharing the Crank and Cam sensors since they can be touchy, maybe someone has already done this with success?
Thanks in advance, Dan
Parallel MS3x and LSx 0411 ECM? Anything special?
Re: Parallel MS3x and LSx 0411 ECM? Anything special?
Sorry I see a post on it already here... Feel free to delete this whole thread.
http://www.msextra.com/forums/viewtopic ... 1&start=20
Thanks, Dan
Thanks, Dan
