Will a serial connection with USB 2 serial cable work to run Tuner Studio with laptop? I'm having Bluetooth communication problem, already tested Bluetooth adapter, I'd like to test DB9. (MS3 USB does work).
USB to Serial DB9 Cable
Re: USB to Serial DB9 Cable
may well do the db9 serial port is on the main board not the ms3 processor card, i would try getting a serial adapter that uses the fdti chip though.
