Its getting cold here now and my tune is starting to change,so I went to the air temp correction table and noticed it was reading coolant temp. Is there something I can do?
MS3, V3.0
air temp correction reading coolant temp
Re: air temp correction reading coolant temp
can you trace back the wire to make sure the sensor plugs didn't get switched or shorted together. Otherwise I believe that you can go to the input section to see what pins are being used in tunerstudio and make suse that you have the MAT sensor pin input at the right wire in the harness.
Good luck.
Good luck.
Hi
You have set your "MAT/CLT Correction" to 100% CLT!
Frank
Frank
nathaninwa wrote:Its getting cold here now and my tune is starting to change,so I went to the air temp correction table and noticed it was reading coolant temp. Is there something I can do?
MS3, V3.0
That fixed it. Weird, I never changed that table and all the other defaults I've setup have been 100% airremp
