looking at the instructions, http://www.msextra.com/doc/ms3/knock_module.html the picture talks about flying "leads" and shows wires from pad k1 AND k2, but the instructions only talk about K2...... I'm confused....
and do i soldier up the two "support" pins to the bottom boards pins? no issues?
Knock Module Install question!!!
81 Porsche 928. 5L 16v, MS3X CNP- full sequential
Re: Knock Module Install question!!!
OK! figured it out mostly. K1 to pad 16 , and K2 to pad14 on the DB15....
wires from the bottom or top of the card?
I put the wires in from "underneath" the knockboard ,and then solder it from the topside.
I used SPR1 and SPR2 on the V3 mainboard DB37 for input, so cant tell you there.
Toyota JZX90 Mark II drifter
1JZ-GTE, 12+1 on MS3x, 6x LS7 D514's, 510cc, all stock sensors
