Not sure where this should be so please move as needed.
Just got my LC-2 wideband installed and the controller shows solid green so I know its working but in TunerStudio, the only output it shows is either 10.10 or 19.90. Nothing in between. I connected the yellow wire (analog 1) to the o2 input on the relay board. It's grounded on the battery along with the ECU. Maybe a TunerStudio setting? FYI, in the project properties I have it set for wideband as well as under AFR/EGO Control. Is there something I am missing?
odd wideband output
odd wideband output
1966 Mustang Fastback
302 HO,Trick Flow TW 170 heads, Headers/dumps, MS3
Re: odd wideband output
AFR table calibration under the Tools menu.
DOH! I knew there was something I was missing and it was staring me in the face. Thanks! I'll give it a check over when I get home.racingmini_mtl wrote:AFR table calibration under the Tools menu.
(FIXED) odd wideband output
Once I got into the AFR Table Calibration and selected the correct o2 sensor, that solved it, as expected. Thanks again!
