LS3 with 58x, cam input
Im going to be running the 58x crank and will be deleting the gm vvt for a standard setup, but default is a 4x cam gear, I dont see an igniton code for this, would I benefit from the LS2 1x cam gear and run poll level?
Re: LS3 with 58x, cam input
Just select "Poll level" and it will work.
Thanks James, I'll get the default 4x gear then. And sequential is still abailalble with that gear? Thankyou
Edit, nevermind, just went through the Pro manual and found the info I needed under the LS1 section.
