Was wondering if twin trigger will work well on a bike install using twin hall sensors on the crank, on the cam input and crank input using the MS3x. Would it be better to install the new crank/cam input board from JB perf to avoid high rpm crank/trigger sync loss. I absolutely know the new board works better for VR sensors but what about a slow moving hall sensor ?
Any Ideas are all ways appreciated !
Thanks, Jeff
Another New Bike install with questions
Fastest MS powered vehicle on the planet ! 6.60@208mph
Re: Another New Bike install with questions
My dual VR board will work fine with hall sensors but so should the V3.0/V3.57 and MS3X VR circuits. You just need to adjust the pots as per the manual.
