2JZ VVTI Syncloss
2JZ VVTI Syncloss
i have a 2jz vvti with MSpro board , i manmged to start the car with everything is perfect , even driving the VVTI
the problem is i cant get pass 5000rpm always get reason 84 . is there any help in this i tried and searched all i found is to put 10K resistor inline
i need to confirm from someone that this will help in my status .
i attached the MSQ and the composite logger
Re: 2JZ VVTI Syncloss
There's lots of noise on your cam signal - see frames 28,29,30,31 in the composite log.
how to know if i have the right wiring for the cam? or do i need to wire the opposite way? i think when the bars are up this means they are the right way right??
so if it is only noise is this a shield problem , or from the log i can see many false trigger so do adding inline 10K resis will clean the signal or do i use the software filter??
and why there is no sync loss bars in the log ???? this makes me go crazy . do they appear only if happen loss on the main trigger?
This is what I'm seeing:
However, as you note, there doesn't actually seem to be any synchloss in the data you captured. You can use the "Sync loss logger" to record the signal that led up to the sync loss.
That cam signal is seeing false signals for sure.However, as you note, there doesn't actually seem to be any synchloss in the data you captured. You can use the "Sync loss logger" to record the signal that led up to the sync loss.
a lot of false signal can be filtered using 10k inline right? . to bring down voltage as it happen before with another setup using the ms pro bare board . may be there must be hardware fix for that as i started to this this error a lot .
With MS3-Pro (and Microsquirt) you use a 10k resistor "shunt" between VR+ and VR- connections.
(The V3 and V357 mainboards can use the 10k resistor inline.)
really ? i have a project i used 10k inline with the vr + , it was the bmw vr sensor wich always needed as it produce high voltage on high rev and it worked . do you think i should put it shant not inline ?
See section 4.3.0.1 in the current MS3-Pro manual.
thanx but in the current firmware I can't change the edge of the can sensor in the 2jz vvti trigger
if some else landed here for the same reason here is some info that would help
http://www.useasydocs.com/theory/vr.htm
the MAX992X is the same as the one in mspro . I've used common -v signal for both can and crank I will try to separate them from each other
That is likely the cause of your problems.esso wrote:I've used common -v signal for both can and crank I will try to separate them from each other
