Greetings all,
EGO Control "simple" correction is giving me quite large oscillations of AFR, so i gather i need to move to PID control.
Does anyone know what PID settings are equivalent to the "simple" setting?
Ill use those settings as a starting point and tweak from there.
Here is an example of what im seeing:
Thanks.
EGO Control equiv "simple" PID settings?
Toyota Celica GT4/Alltrac with 5S-GTE stroker (2.2L I4 turbo, high CR) on E85 w/FlexFuel.
MS3 + MS3X + KnockBoard + RTC + BT + DIY CAN-IO-Board + DIY CAN Digital Dash.
Re: EGO Control equiv "simple" PID settings?
I run stepsize of 1 and the new lambda delay and authority tables, works pretty darn good with just "simple"
Thanks.
Yes, now that you mention it, the EGO delay is probably the cause of this.
I have this problem with using the table though: http://www.msextra.com/forums/viewtopic ... 31&t=54644
Load up pre1.4 alpha 7, the delay table now goes to 11, er, 2.550 seconds(the last digit rounds up/down), which is reasonable at low MAP and RPM. (Even idle) and maybe even a post cat sensor.
There is also a fixed "response time" that I'm kinda of mixed feelings about, as the sensor response time depends on a LOT of things, but it provides a little more time I guess if needed.
The delay table (now with X10 range) should be sufficient, even on a weak motor with long tube headers.
Thanks.
I think ill persist with 1.3.3. I want to stay away from the alpha/betas for the moment.
Good to know its been changed though.
I think I ran release code for about 30 minutes in the last 4 years...
Only had a hiccup once on very early ms2 sequential code that was fixed in under an hour, from many time zones away.
