A/C idleup doesn't work with PWM% above 49
Firmware version MS3 Beta 1.2.2 2013 0424 21:35
I am using the A/C idleup function, and it works fine if the PWM% is 49 or below, above 49 the a/c indicator in TS will come on, but it does not open the IAC.
Will a firmware upgrade fix this?
See attached MSQ file.
Re: A/C idleup doesn't work with PWM% above 49
As you are on experimental beta code, I would first try the latest stable release.
I just tried this again on 1.5.1 and it still doesn't work.
It ignores anything above 50%
I didn't see that the file wasn't attached.
Here it the file, the duty cycle is set now 49% so it works with this file.
- Attachments
- 2019-08-23_15.48.02.msq
- (273 KiB) Downloaded 20 times
Can you also post a tune with the setting beyond 49, and a data log of what is happening?
Here are two data logs, one with the duty cycle at 49% and it works, an another with the duty cycle set at 51% and it doesn't work.
- Attachments
- duty cycle at 49.msl
- (327.43 KiB) Downloaded 16 times
- duty cycle at 51.msl
- (202.1 KiB) Downloaded 15 times
I found and fixed the issue for the next beta.
However, why do you need such a large duty added? How small is the idle valve?
I use it to speed up the engine for rev matched downshifts.
