Capacitor type & rating for LSx ignition coils
MS documentation shows the need (optional) for a pair of caps with the LSx ignition coils. However, cap type and voltage rating are not mentioned.
Since there can be flyback spikes from the coil primary, wouldn't a diode also be required, allowing for a lower voltage cap? Say, 100 volts?
Thanks.
Thanks.
Re: Capacitor type & rating for LSx ignition coils
I don't have any data, but on 6 lq9 coils I installed one capacitor setup from a 1g Mitsubishi coil setup, and to date no problems after 2 years of running
A diode will attempt to remove the flyback pulse - and it's that pulse which is needed to develop the spark. A suitable capacitor will provide a low impedance path to AC currents - ie noise.
Hi,nathaninwa wrote:I don't have any data, but on 6 lq9 coils I installed one capacitor setup from a 1g Mitsubishi coil setup, and to date no problems after 2 years of running
Does it show a voltage rating? Any other information on it that would suggest what type of cap it is?
Where does GM place their capacitors in their applications? It does not appear to be in the wiring harness itself.
Thanks.
As far as I know, they don't.Healey3000 wrote:Where does GM place their capacitors in their applications? It does not appear to be in the wiring harness itself.
Thanks.
Hi,DaveEFI wrote:A diode will attempt to remove the flyback pulse - and it's that pulse which is needed to develop the spark. A suitable capacitor will provide a low impedance path to AC currents - ie noise.
Assuming that the power lead is a low-impedance source (which it should be), the flyback pulse amplitude will not be large. What voltage cap would you suggest?
Thanks.
Interesting. Why do we need it? Does GM do something in their ECU (that we can replicate in MS)?jsmcortina wrote:As far as I know, they don't.Healey3000 wrote:Where does GM place their capacitors in their applications? It does not appear to be in the wiring harness itself.
Thanks.
I'm not convinced that we do. I've not used them.
I'll back up my cap install with an LS I did in which no cap was used and works fine as well
I added mine while tracing down a cranking sync issue, but didn't solve it at the time, but has not hurt at all
Good to know; thanks. When and how did the caps enter MS lore? I see so many websites and forums referencing the Megamanual. Therefore, it must be truejsmcortina wrote:I'm not convinced that we do. I've not used them.
Thanks. No caps for me!nathaninwa wrote:I'll back up my cap install with an LS I did in which no cap was used and works fine as well
I'd say the purpose of this cap is to reduce RFI - mainly for the car radio etc. Same as you'd do with points ignition. But I doubt it's needed otherwise. But also will do no harm.Healey3000 wrote:Hi,DaveEFI wrote:A diode will attempt to remove the flyback pulse - and it's that pulse which is needed to develop the spark. A suitable capacitor will provide a low impedance path to AC currents - ie noise.
Thanks.
IIRC they are usually about 1-10 microF 300v.
No caps here. I dont recall reading anything about them even when i built my harness.
I ran with out a cap and LS coils for several months but was getting alot of noise on the frequency based sensors (maf & flex sensors).
Installing a capacitor fixed the issue 100%
The capicator recommendation came from Megasquirt testing by Bowling & Grippo. See link: http://www.megamanual.com/seq/coils.htm#ls2
Porsche 930 3.0 Slantnose
Thanks; what kind did you use? Did you find that it had more to do with the power bypass caps or the ones on the trigger lines?Dasman56 wrote:I ran with out a cap and LS coils for several months but was getting alot of noise on the frequency based sensors (maf & flex sensors).
The only automotive grade cap I could get was 0.47uf and was placed on the coils power feed. I never had any signal noise on the voltage sensors only the frequency ones.
