My accel is set to Accel pump but there is an issue with the TPSdot.
When I took a log it shows a TPSdot for the first short time then it sits on 0. The TPS shows the correct value but no TPSdot, it sits on 0 and hence no accel enrichment.
I can not see the cause but may have missed a point in the set up.
TPSdot
Re: TPSdot
Is it TpsDot uses %WOT causing the issue?
Re: TPSdot
Checked that but think that it is not the problem. I am getting 0 TPSdot from all TPS %.
Could be wrong...but.
Triumph TR3A. MS3X, IBT, Fully Sequential Injection, Wasted spark, 60-2 crank wheel.
Re: TPSdot
Found the problem. I have set up an Engine Check Light and still trying to set it up. One of the issues is to set the TPS. I still get an error showing. This caused the problem but do not understand why.
Will start a new thread on this.
