No steady rpm signal + no ign output with ms3x
I'm trying to start a Pontiac L67 buick engine V6 3800cc using ms3+ms3x and 6 D585 truck coils ( logic) like the ls1 coils;
The problem is that i can't get a steady rpm reading whatever i do with the resistor pots, and there's no spark output at all from the ms3x... RPM reading range from 244 to 150 to 33 @ cranking..If i try the spark output test, they work;
And lastly i couldn't get the pots to read rpm at all whatever i tried turning them at all...
I'm using a 60-2 crank wheel with a vr sensor(tried several ones) and the original GM cam sensor... Battery voltage is very good @12.9 V at all times because I'm using a backup charger...
Re: No steady rpm signal + no ign output with ms3x
Maybe tooth log and pix of the crank wheel/sensor arrangement, also?
Dochka do you have a JimstimX? If not I highly recommend it however, If you want some more help you could post an MSQ and we could go from there.
Wubba Lubba Dub Dub!!! oh. yea...
1985 Toyota Corolla 20V 4AGE MS3X Seq. Fuel/Spark...
1990 Eagle Talon TSi AWD 4G63 MS3X Seq. Fuel, Batch Spark...
Nice Nickname AE86 drifter, i own an ae86 myselfae86drftr wrote:Dochka do you have a JimstimX? If not I highly recommend it however, If you want some more help you could post an MSQ and we could go from there.
i'LL DO NEXT TIME, YEP I OWN A JIMSTIM
I plugged the jimstim to the ecu and adjusted the resistor pots using the spare knob turn till i've got the ready box light up green when i turn the spare knob, and if i turn it from end to end i get cranking turn green also with full sync...ae86drftr wrote:Dochka do you have a JimstimX? If not I highly recommend it however, If you want some more help you could post an MSQ and we could go from there.
I unplugged the stim and put the ecu into the car's wiring, then got no connection from laptop to the ecu;
I put the ecu back to the stim and got no connection either, when i turn the stim on, the red led lightens up brightly then dies after 10 seconds...
I removed the ms3 card from the ecu then powered it up again, this time the led stayed bright..
What happened to the ms3 card ???
I rechecked everything, the ribbon cable, the socket voltages... Everything looks right
Other posters have been asking you to attached an MSQ and datalog.dochka wrote:Any help with my issue ?
I can't connect to the ms3, i think the ms3 card is fried for some reason i don't knowjsmcortina wrote:Other posters have been asking you to attached an MSQ and datalog.dochka wrote:Any help with my issue ?
Is there a way to test it or repair it ?
Try reloading firmware?
Or testing the serial comms per the build instructions:
http://www.megamanual.com/ms2/V3assemble.htm
http://web.aanet.com.au/arran
There's no connection between the ms3 and the laptop whatever i do...jsmcortina wrote:Try reloading firmware?
I've got another Megasquirt just to compare, I connected the new megasquirt 3 to the JimStim and powered it, instant connection, I put the wheel pattern to n3 (36-1) and put 2 jumpers in the jimstim to get rpm as per the manual, and i've got rpm and i turned the rpmC and rpm fine, everything worked and the led's in the jimstim blink...
Then I uninstalled the ms3 card and put it in place of the burnt one, instant connection too, but I get no rpm whatever i do with r52 and 56...
I suspect these to be the culprit, and the difference between the 2 megasquirts is that one has MC34072AP and the other (the working one) has the LM2904N for U7
Also, the working ecu has a Blue R52, the non working ecu has both the r52 and 56 silver
"put it in place of the burnt one"
The burnt one, when did that sneak into this thread??? Tell us more about what you have going here... What's "burnt" the MS3, MS3X, or mainboard? What version of mainboard? What did this "burning" consist of, what components? Has it been repaired? What caused the burning?
Edit: Okay, found this:
"i think the ms3 card is fried for some reason"
Is there any symptom other than not connecting to TS?
The ms3 card is friedbillr wrote:"put it in place of the burnt one"
Yes, when i power the jimstim attached to the ecu, the power light in the stim dies after 10 seconds and you can barely see it turned onbillr wrote:"put it in place of the burnt one"
Okay, it sounds like you have more than one set of MS3, MS3X, and mainboard, and that at least one combination works OK. So, as you swap things around, do you have two good mainboards and only one good MS3, or is it the other way around, two MS3s that work with only one mainboard? Let's ignore the MS3X for now, until you can connect to TS, and I suggest you disconnect that from the MS3. If it is a bad mainboard, have you checked voltages on the 40-pin socket, per the manual?
Edit: I re-read the thread, it sounds like you have one MS3 that won't connect, and one that connects but you don't get an rpm reading; two kind of different problems. I get kind of confused talking about both at the same time, can we focus on one or the other? For the "no connect" one I suggest making the 40-pin socket voltage readings, but with the MS3 plugged in; let's see if the 'bad" MS3 is pulling down either the 12 or 5V supplies. For the "no rpm" one, have you posted tooth, comp, and run logs, as well as .msq? (I'll go back and look for those earlier in thread).
Edit2: No, it seems you have been reluctant to post the info requested. Why???
I have the main boards working okay and one ms3 card , the other is the problem;billr wrote:Okay, it sounds like you have more than one set of MS3, MS3X, and mainboard, and that at least one combination works OK. So, as you swap things around, do you have two good mainboards and only one good MS3, or is it the other way around, two MS3s that work with only one mainboard? Let's ignore the MS3X for now, until you can connect to TS, and I suggest you disconnect that from the MS3. If it is a bad mainboard, have you checked voltages on the 40-pin socket, per the manual?
How to check the voltages with the ms3 card plugged in ?
I've checked all the voltages in the main board with no ms3 card attached and everything is in spec;
For the data logs, i don't have any..
I posted the msq file,
What info is else needed ?
Were run, tooth, and comp logs posted before; did I miss those? Check for voltages at the 40-pin socket, with (the bad) MS3 plugged in by probing against the side of those little sockets, you will need a fine-tip meter probe.
Today, I managed to start the engine by using another Megasquirt V3 board and it's MS3 daughterboard, and by using the MS3X card along..billr wrote:Were run, tooth, and comp logs posted before; did I miss those? Check for voltages at the 40-pin socket, with (the bad) MS3 plugged in by probing against the side of those little sockets, you will need a fine-tip meter probe.
The engine started after I set the Req Fuel to 40ms which i believe is very high considering the engine is mated with 600cc injectors and using an aftermarket fuel pump, and the VE table values are too high also... I get the "CamFault" error, but the engine started on both "sequential" and "semi sequential" modes.
How to set the crank and cam phasing relative to each other? What i have done is added a 60-2 wheel to the crank pulley and put the crank sensor approx 8 teeth before the missing tooth, but the cam sensor system is left untouched..
It ran about some 25 min, then i turned it off, but when i tried to restart the engine, it didn't fire up... No ignition and fuel output this time;
I rechecked everything, even tried the output test mode that works, and i get steady cranking rpm, but i have no outputs at all...
Here's the .msq file attachedbillr wrote:Were run, tooth, and comp logs posted before; did I miss those? Check for voltages at the 40-pin socket, with (the bad) MS3 plugged in by probing against the side of those little sockets, you will need a fine-tip meter probe.
There's no output for injectors or coils while cranking...billr wrote:Were run, tooth, and comp logs posted before; did I miss those? Check for voltages at the 40-pin socket, with (the bad) MS3 plugged in by probing against the side of those little sockets, you will need a fine-tip meter probe.
But output test mode works fine..
I checked the voltage at the injector clip and it reads approx. 9v when on the ignition ON and ecu powered on, which should be 0v i believe ..
If i unplug the MS3X and turn the ignition switch to ON again, the multimeters measure 0v
Could it be a short in the ms3x board?
