Hi I'm trying to get the car started. I'm a newbie when it comes to MS3.
The car cranks but tunerstudio reads 0 rpm when cranking. Adjusted CPS sensor to spec and checked spark plugs.
I have checked all of the wirings and ignition setting on tunerstudio is set to 99-05 miata.
Would like to get it started tonight but am struggling through this. Help would be greatly appreciated.
I'm using a base map from Dimitris for MS3 basic right now.
ms3 basic crank, no spark no rpm signal vvt motor into 94-97
Re: ms3 basic crank, no spark no rpm signal vvt motor into 9
did you have a JimStim? If so simulate everything before installation in the car.
MS3 is not seeing your CPS or it would recognize that you are cranking an attempt to sync. once it gets the signal from your CPS and everything else is wired correctly, you should get spark. No CPS signal = no spark
do you know how to open the tooth logger in Tunerstudio? if you are not getting anything there then you more than likely have a setup problem. review the assembly manual about the jumpers needed for your style CPS.
I am new as well, but i hope this helps some. and if i am wrong, experienced members please correct me.
...if you dont have a JimStim then i would suggest getting one or borrowing from a friend.
I would say post a tooth datalog but i dont think it will help in this case.
unfortunately I don't have access to a JimStim.
I've attached my csv file. Hopefully i can find a solution.
I was told to check both my CPS and CAS signal.
