LS2Z28 black_2015-01-26_18.02.42.msq
Finally got this high compression dude running and really need to make sure the knock sensors are dialed in so that this motor doesn't pop a piston like the last one lol! Does anybody have beginning parameters for the Bosch sensors that bolt on both sides of the bottom of the block on the 6.0L ls2? I will post an MSQ as soon as I get it but it rattles to beat the band with the junk fuel I have in it from last years power tour so it should be easy to at least get close but I can't seem to get any sensor effect at this time anyhow. Thanks again to the best support group ever!LS2 knock sensor parameters
MS3X V 3.57
73 Z28 Camaro 6.0 LS2
Re: LS2 knock sensor parameters
Have it up and running and the flat response knock sensors make the knock meter move up from 3.3ish to 4.5 ish when knock happens. Happy with that, now how to get that to retard timing.
MS3X V 3.57
