v10 36-1 wheel, usable?
i ran across a relativly cheap ford 6.8l v10. its even fire and factory 36-1 trigger wheel. i know that in the past the # cylinders bust be divisible by # teeth, just wondering if this still applies.
Re: v10 36-1 wheel, usable?
I thought Ford V10s used a 40-1 crank wheel, but I would be interested in the answer as well as I have a customer asking about a 36-1 cam wheel on a V8.
For even fire engines, most certainly the number of teeth per cam rev must be divisible by the number of cylinders. (So V8 won't work with 36-1 on the cam.)
For oddfire I need to double check - it is possible that it could be made to work, but it will depend on the oddfire angle.
Matt Cramer wrote:I thought Ford V10s used a 40-1 crank wheel, but I would be interested in the answer as well as I have a customer asking about a 36-1 cam wheel on a V8.
you may be right, however i can't confirm either way. no pics exist that i can find and parts diagrams/ service manual all show v8 engines since they are similar.
Wouldn't you still need to have a wheel with a multiple of 5 as the number of teeth? So that would still make a 36-1 invalid.jsmcortina wrote:For oddfire I need to double check - it is possible that it could be made to work, but it will depend on the oddfire angle.
It depends on whether the odd-ness could put the trigger on an actual tooth and whether the code would allow for that.racingmini_mtl wrote:Wouldn't you still need to have a wheel with a multiple of 5 as the number of teeth? So that would still make a 36-1 invalid.jsmcortina wrote:For oddfire I need to double check - it is possible that it could be made to work, but it will depend on the oddfire angle.
I thought the code used the actual teeth for half the cylinders and an offset from actual teeth for the odd cylinders. Which is why I thought the requirements were the same whether it's even or odd fire.jsmcortina wrote:It depends on whether the odd-ness could put the trigger on an actual tooth and whether the code would allow for that.
