hi guys
just a sanity check, i take it that duty cycle 1 variable is still a valid reading when using ms3 in sequntial mode
and gives the duty cycle value of all injecters as not doing any induvidual trimming .
bill
duty cycle 1 with ms3 sequntial
Re: duty cycle 1 with ms3 sequntial
Yes. Just make sure it's set to 1 squirt simultaneous or 2/alternating as other settings can affect the accuracy.
Thanks matt yes the software was right we realy were hiting 100% duty at .5 Bar of boost on a set up that should run up to 1.2 bar standard nice when you think about it pull an injecter and find that the wee gause filter in it is full of bits of rubber hose and metal swafe and the second third and fouth . ..... yes no filter just a strainer in the tank lesson OEMs dont fit filters if you dont you need them . fuel presure gauge showing good presure but ms pointed the way with the duty gauge .. topping out and the high values needed in the ve table .
