A/C Idle up - power in, nothing out
Got the configuration issue out of the way. Double checked the wiring, everything ok. Settings looked ok so fired up the motor and flicked the a/c switch.
I have 12 volts going to the Nitrous In wire, Check
The ecu changes the revs and shows the a/c has been activated, Check
There's 0v coming out the Nitrous Out 1 wire,
Am I missing something? I know the Nitrous Out has a maximum 3A,is it possible it was overloaded and if so can it be reset?
I cannot see anything unusual in the operation apart from no +ve output of any voltage on the Nitrous Out wire.
1UZ-FE Volvo 282
CoP Sequential MS3x
CoP Sequential MS3x
Re: A/C Idle up - power in, nothing out
Nitrous out is a grounding output.
Oh. Ok. Didn't see that in any of the wiring detail.
That should overcome the issue. Thanks
1UZ-FE Volvo 282
CoP Sequential MS3x
CoP Sequential MS3x
Try here: http://www.msextra.com/doc/pdf/html/MS3 ... .3-48.html1uzfevolvo wrote:Oh. Ok. Didn't see that in any of the wiring detail.
Re: A/C Idle up - Wiring
Ok, so got the wiring completed.
Nitrous In - 12v
Nitrous Out - Gnd
With the MS controlling the a/c, I cannot turn the a/c off at the switch. Have double checked the wiring. With the ignition on, there's 10.2v showing on the Nitrous In wire, and this is with the switch wire disconnected.
Why is the Nitrous In wire showing a voltage?
Nitrous In - 12v
Nitrous Out - Gnd
1UZ-FE Volvo 282
CoP Sequential MS3x
CoP Sequential MS3x
Sounds like you might have JP7 installed on the MS3X card. Remove it.
I assume you mean the JP7 jumper. This is in a plastic bag on the work bench.
If this is an issue, I could re-wire to a ground input.
1UZ-FE Volvo 282
CoP Sequential MS3x
CoP Sequential MS3x
