Something strange happened few days ago, to make the long story short, MS3-pro was installed on 2JZVVTI two weeks ago. The car was working fine, during the dyno session (few days ago) the car went rich all of a sudden, and started flooding. At idle the wideband reads 10 until it dies. All pistons became flooded of fuel.
We thought that the injectors got damaged, we sent them out for cleaning and repair, installed them back, no change. Then we got new identical set (ID1000), and the same thing. I swapped the ecu with the one of my car, the customer's car is working fine.
I updated the firmware of the ecu, and no luck still flooding. If you came the same issue before, or you think that the injector driver in the ecu is damaged and we can do something please lemme know.
Thanks,
Damaged ECU
Damaged ECU
Re: Damaged ECU
you might the serial no. of the ecu: 300145416711
Re: Damaged ECU
It is best to contact your supplier directly for a faster response.
