MS3 Pro Synch lost at 3500 rpm
botasjr
Post by botasjr »
hi
im instaling an ms3 pro on a engine with 36-1 whell and ford vr sensor
i lost synch at 3500 rpm, i just have change the wires, the edge on the software, but is always the same, no diference.
does the ms3 pro have some pots to adjust or other method to tune the signal???
i didn´t changed the gap between the sensor and the whell, could be a problem???? the sensor is very close to the whell.
regards
grom_e30
Re: MS3 Pro Synch lost at 3500 rpm
Post by grom_e30 »
try a shunt resistor across the vr sensor wires 10k should do it.
nathaninwa
Post by nathaninwa »
You can also try a 1k to 10k resistor inline on the pos wire. There are blue and yellow resistors that come with pro just for this
botasjr
Post by botasjr »
for now, i can reach the 6500 rpm with this resistor
thanks all
