Android equipped radio to display MS obd2 CAN data?
Hi, is it possible to wire up an obd2 connector and one of those obd2 bluetooth antenas to display data on a bluetooth/android equipped radio?
I wonder how would the wiring be done? regarding the obd2 connector pins and MS pins
Obd2 universal antenas example (maybe someone can pinpoint the best one out of these)
http://www.ebay.com/itm/New-Torque-Andr ... ls&vxp=mtr
Android equipped radio example
http://www.ebay.com/itm/Android-4-1-7-D ... da&vxp=mtr
Re: Android equipped radio to display MS obd2 CAN data?
Megasquirt doesn't talk OBD2.
If this antenna was able to send CAN data, would it maybe work? (using the CAN pins on the MS3)
thinking about it again I think we have a bluetooth device by the efianalytics guys right? maybe we can install their software on the Android radio...
If you can find an android radio that supports Bluetooth for anything other than phone hands free you are doing better than me.
http://web.aanet.com.au/arran
What James is saying, is for one you may not be able to connect the MS Bluetooth to any of the OBD wireless bluetooth radio's since they both do essentially the same thing... try to talk to a PC or smartphone, and since the OBD dongle radio is actually most likely an ELM327 OBD based adapter with a simple bluetooth radio connected to the RX TX pins... the MS software simply does not talk to the ELM327/OBD adapter... meaning it doesn't send or receive any OBD related info. The MS bluetooth radio and any OBD Bluetooth dongle you find are setup to talk to a PC or smartphone, the MS bluetooth adapter intended really only for the MS software only.. Even if you were able to get the MS Bluetooth adapter connected to the ELM327 based OBD dongle, reading OBD info is an entirely different kind of flying... altogether. While I'm sure it would be fairly easy for James to make this ELM327/OBD functionality work by itself on MS hardware (especially since I have it all mapped out and working on a stand alone Arduino type chip), it would most likely interfere and slow down the functions of the MS as an engine controller if he were to try and merge it into any MS software would not really be beneficial anyway since the MS is intended to be it's own engine controller... not something that reads OBD commands/signals.
Furthermore, there's no LCD on the MS.... so really your better off just using your Android Torque app, with one of these Ebay OBD Bluetooth dongles... done. Or use a PC the same way with an app like Scanmaster...
MS3X on 2010 Camaro LS3 + Whipple @ 10psi + HPT + AEM 30-0333/0334 WB
MS3 Knock Module + JBPerf Dual VR v2.1 (Removed), didnt play well with LS3 DBW Motor, works for VSS.
OLD: 1997 Chevy Z71 Vortec 350, + BOSCH 0261231036 WB Knock Sensor
OLD: LT1 TA 700hp + MS3X
I discarded the obd or elm dongle from my thoughts and just thought .... Install the bluetooth antena from efianalytics, then instead of using a cell phone where you would normally install their app, use a the android equipped radio... nope?
I have mine hooked up to an android radio with usb
Very nice, could you give us the specs of the unit? I was thinking about this tooo...
fun is not a straight line
Sven
Sven
It's just a android radio that I got off ebay and it runs a combination windows ce and android but the blue tooth only works on the windows side so I use the usb connection for the megasquirt. ..I think if you got a pure android radio the blue tooth may work if that what you after but for me the usb works great and I have shadow dash and msdroid both installed and working
great!!! I guess we could use either usb or rs232 (with a converter) to use the radios usb connector? Looking very good there!
As long as it has usb for the android part of the radio or one of the new pure android radios I have been seeing
