open-loop pwm fuel pump control for a1000
jb007
Re: open-loop pwm fuel pump control for a1000
Post by jb007 »
Oh I nearly forgot... thanks for the circuit in the first place. :D
Jim
1968 Australian Morris Mini fitted with a 1310cc A+ engine
14point7 WB, TunerStudio MS Ultra & MegaLogViewer HD
My Blog: http://www.jims-blog.com
jb007
Post by jb007 »
Hi Matt. Just to let you know that I haven't abandonded the PWM Motor Controller circuit. I've been unwell and just havent had the energy to do much. I have though designed the PCB and have all the parts. I will be using the circuit to also control my thermo fan under control from the MS. If you have time, check out my blog http://www.jamesobartlett.com :RTFM: for updated info. Have you progressed at all?
Jim
TheSilverBuick
Post by TheSilverBuick »
Just want to follow this since I have an A1000 ready for a straight six engine with a turbo and it certainly doesn't need all 1000 for highway driving.
matthunter1448
Post by matthunter1448 »
still looking forward to it i haven't got my pump in yet but hope to get it done soon
matthunter1448
jb007 wrote:Hi Matt. Just to let you know that I haven't abandonded the PWM Motor Controller circuit. I've been unwell and just havent had the energy to do much. I have though designed the PCB and have all the parts. I will be using the circuit to also control my thermo fan under control from the MS. If you have time, check out my blog http://www.jamesobartlett.com :RTFM: for updated info. Have you progressed at all?
Jim
Any luck recently I'm about to mount my fuel system so...
jb007
Post by jb007 »
I'll be testing this Wednesday Oz time. I had to change the design to sit my setup so that and work has got in the way.
I'll post here and on my blog the full details.
Jim
jb007
Post by jb007 »
jb007 wrote:I'll be testing this Wednesday Oz time. I had to change the design to sit my setup so that and work has got in the way.
Jim
Well i finally got to it. Bottom line is after bench testing the prototype, I decided not to go with it, at least not in it's current form. I have found some SSR's that will handle PWM frequencies up to 3500Hz, or so the specs say. Further details on my blog.
