finally got my 2jzgte vvti running. I am just running off the "default" ve table and ignition table in Tunerstudio. I plugged in some numbers into the ve table generator and this is what I got.
I am idling a little high due to not running any IACV. Its a track car, so as long as it stays running I dont need any comforts there. I put in numbers that are close to stock for now. I wasnt sure about kpa at power levels. Seems like I should be at max boost at those rpms? although 3600 rpm might be early for that boost level. Does it seem like a lot of fuel in that map at the middle and top end?
ve table generator
Re: ve table generator
also, is there somewhere I can generate an ignition table? or maybe an excel file?
